Hello.
So i was following the OS Upgrading process of a tutorial shared with me via and old post i made and this is what happened:
I checked my calculator requirements, downloaded some upgrade .bin files, processed them with PolyOS software and tried to flash the one i selected to the calculator using FX-Remote 2.03, it got the file, the calc recieved some data and a pop appeared saying that it detected a GII model and i had to wait for it to display "waiting" and then continue but the device gets stuck at the unknown BIOS (serial numbers i guess) and press restart button but it doesn't display what it should causing the failure of the process so i have to go through it all over again with no result so, can somebody help me solving this problem please, if possible please reply.
Thanks in advance.
PS: the upgrading tutorial link is the following:
https://tiplanet.org...hp?f=96&t=19592
No replies to this topic
Posted 28 October 2019 - 06:41 PM
- kstc05 likes this
Also tagged with one or more of these keywords: Fx-7400GII, OS
Calculators →
Casio CFX/AFX/FX/Prizm →
download & install conicsStarted by Just_A_Noob_Here , 11 Dec 2024 ![]() |
General →
General Discussion →
OS update error.Started by kstc05 , 25 Dec 2020 ![]() |
Calculators →
Classpad →
OS 2.2 -> 3.0 with ClassPad 300+Started by sijisu , 06 Oct 2019 ![]() |
General →
Your Projects →
Guess Number - Instructions & Tutorials threadStarted by CalcLoverHK , 28 Jun 2019 ![]() |
General →
Your Projects →
Guess Number - Updates & Bug Reports threadStarted by CalcLoverHK , 25 Jun 2019 ![]() |
