Need Hardware and Information on sending data to Casio Label Printer
printer labeler serial documentation
#1 RufusVS
RufusVS
  • 3 posts
    I don't have any fancy CASIC calculators, but I have Casio Label maker, and I'm trying to make use of them through the data interface used by CASIO calculators!
Posted 26 February 2023 - 05:29 AM
I just picked up an old Casio KL-2000 label printer (I also have the KL-60.  I noticed the KL-2000 has a communication mode
and port on the side that was meant for a calculator (or possibly computer) interface I believe.  I would love to be able to
load and unload labels from my PC rather than keying them in on the keyboard.
Casio is out of the label printing business and only sells tape cartridges, so they aren't much help.
I would rather not have to buy a compatible calculator and interface cable to get this to work.  I imagine it is just a
serial connection and from searching the Web it looks like a simple 9600 baud interface, but without knowing the
protocol (or for that matter, knowing which pins on the connector are what) I don't think I'm going to be able to do
it.
Does anyone have access to the protocol documentation and/or schematics for the cabling?  Or point me in the
right direction.  I certainly won't get far as the label printer is probably a receive only device, so I can't just throw
characters at it hoping to see results.
I currently have USB Uarts with RS232, RS485, and TTL versions, so I imagine one of them might work.  Or
advice on the most recently supported hardware.
Plus, of course the protocol, or program source code that did the communication that I might be able to read
enough of to create my own driver.  (I am an Embedded Software Engineer, so I can read most computer
language and write in several, so that won't be a problem)
#2 HappyCalc
HappyCalc
  • 67 posts
  • Interests:Programming, On-Calc Programming(C.Basic), Gaming, Origami, Eating Chocolate
    fx-9860GII-2
    fx-CG50
Posted 26 February 2023 - 12:49 PM
The connector looks like the 3-pin connector used by current CASIO calculators.
If CASIO didn't change their serial protocol much since they released the KL2000, it might be compatible with current calculators. I doubt so, but it would be worth a try. You can find the protocol of current calculators here: https://bible.planet.../fxReverse2.pdf
They use 0v - 3v for the communication.
You could try sending a start packet from an arduino or your USB/UART interface and check if it reacts.
Edited by HappyCalc, 26 February 2023 - 12:49 PM.
Also tagged with one or more of these keywords: printer, labeler, serial, documentation
