Download here: http://www.casiocalc...amp;load_that=1
PS: I think we can play Zelda by GnuBoy in next ver
Posted 07 August 2007 - 10:16 AM
Posted 08 August 2007 - 05:23 AM
Posted 08 August 2007 - 06:52 AM
Posted 08 August 2007 - 08:13 AM
Posted 11 August 2007 - 03:08 PM
Posted 11 August 2007 - 06:05 PM
Posted 12 August 2007 - 10:39 AM
Posted 12 August 2007 - 12:34 PM
Posted 12 August 2007 - 01:14 PM
Posted 12 August 2007 - 02:54 PM
Posted 12 August 2007 - 06:11 PM
Posted 12 August 2007 - 06:26 PM
Posted 12 August 2007 - 07:18 PM
Posted 12 August 2007 - 07:29 PM
Posted 12 August 2007 - 07:57 PM
Posted 12 August 2007 - 08:48 PM
Posted 13 August 2007 - 01:11 AM
Posted 13 August 2007 - 07:28 AM
Posted 13 August 2007 - 04:56 PM
Posted 14 August 2007 - 09:00 PM
ClassPad is also for games. Enjoy your calc !
Posted 15 August 2007 - 01:07 AM
Posted 15 August 2007 - 07:28 PM
ClassPad is not for games. Upgrade the CAS!
Posted 16 August 2007 - 10:15 AM
Are you sure "ClassPad is also for games"? May I remind you that ClassPad has a poor dim display, which is also monochrome (gray scaling isn't a solution), plus there is no sound? If you bought Classpad for playing games, you are a fool and/or a masochist. You could buy a gameboy or playstation2 instead: with the same amount of money, you get a much-much better gaming console.
fast & easy....
Posted 16 August 2007 - 01:59 PM
Posted 16 August 2007 - 02:17 PM
Posted 16 August 2007 - 02:35 PM
But anyway, do as you wish. You want to play games, and you think that ClassPad is the ideal machine to do this? That's your (serious) problem.
I doBut anyway, do as you wish.
Posted 17 August 2007 - 03:59 AM
Yes.Are you sure "ClassPad is also for games"?
ClassPad 300 Plus has a btter display and I can still see it fine on the ClassPad 300.May I remind you that ClassPad has a poor dim display,
Grey scaling is an option and makes some things alot better than they once were (eg GnuBoy).which is also monochrome (gray scaling isn't a solution),
Yes there is, I have made some sounds on my ClassPad 300 with Vanhoa's OWBasic.plus there is no sound?
I didn't.If you bought Classpad for playing games,
Yes, a Playstation is alot better. And yes, if you bought the ClassPad 300 JUST for games then you are a fool. But none of us bought a ClassPad 300 just for games, we bought it because...well I did because I was told to by the schoolyou are a fool and/or a masochist. You could buy a gameboy or playstation2 instead: with the same amount of money, you get a much-much better gaming console.
I agree entirely. Try playing a PS3 in class (or even a PSP for that matter) without the teacher noticing. You can easily play a game on a calculator because the teacher thinks you are doing work on it. (I know this sounds bad...but what the heckI don't buy classpad for playing, I just said everybody can play on classpad...
ClassPad has never been the ideal machine to do this but try to play ps3 in your classroom while a bloody boring class !!!![]()
I know cp is above all to work and I bought it in order to do that, but I think we are not forced to limit it to that.
The ClassPad isn't the ideal machine for games, a Playstation or Xbox is (depending on what one you prefer which is another debate entirelyBut anyway, do as you wish. You want to play games, and you think that ClassPad is the ideal machine to do this? That's your (serious) problem.
Posted 17 August 2007 - 09:16 AM
Posted 17 August 2007 - 09:44 AM
No you are not, but we are a negligible minority, and we have to live with thatAm I the only one who bought a ClassPad just to be able to write programs for it?
Posted 19 August 2007 - 06:15 AM
Posted 20 August 2007 - 05:07 AM
Posted 20 August 2007 - 07:26 AM
Posted 20 August 2007 - 10:37 PM
Posted 21 August 2007 - 08:26 AM
Posted 21 August 2007 - 12:44 PM
Posted 21 August 2007 - 07:37 PM
Posted 04 September 2007 - 10:33 PM
Posted 04 September 2007 - 11:09 PM
Posted 05 September 2007 - 08:07 AM
Posted 05 September 2007 - 09:14 AM
