Hi All,
I recently had to shift from a 991 ES to an 82 ES plus because an exam board would not allow "High End" calculators. Anyways, when trying to compute the standard deviation or mean in the stat mode, after entering data, I am not getting the var option after pressin shift+1. I am only getting Type, Data and Edit.
Can you guys please help me with where I might be going wrong and if there is a way to reset the calculator if its a software malfunction!
Cheers,
Varun
Please Help With Issues With Fx 82 Es Plus
Varuniyer
, Nov 23 2012 11:27 PM
calculator fx 82 es plus stat variance mean standard deviation
Posted 23 November 2012 - 11:27 PM
Posted 01 December 2012 - 12:34 PM
Hello Varuniyer and welcome to UCF! You should introduce yourself.
According the manual it should be there... Maybe its in another page and you have to press a key to view it? If after pressing shift+1 you press the key 4 what happens?
Also tagged with one or more of these keywords: calculator, fx 82 es plus, stat, variance, mean, standard deviation
Calculators →
Casio CFX/AFX/FX/Prizm →
download & install conicsStarted by Just_A_Noob_Here , 11 Dec 2024 |
General →
Your Projects →
MyCalcs, a website for all the graphing calculator collectionsStarted by adriweb , 03 Aug 2022 |
General →
General Discussion →
[Question] Looking for the best Casio Calculator for inverse matricesStarted by blackburnfjames , 09 Oct 2021 |
General →
fx-CG50 AU Stuck on Language Screen!Started by htt , 23 Mar 2021 |
General →
casio fx-85ES Plus Thai version conversion challengeStarted by Tai , 02 Jun 2020 |
