Posted 13 December 2012 - 09:19 PM
So how do I upload it here?
Posted 13 December 2012 - 10:01 PM
So I finally got around to programming something in BASIC. A little program that converts base-10 integers to any other integer base (up to 36, but I could add more characters I guess).
Well, I think you would have to do it through the file sharing since attachments are disabled.
Posted 15 December 2012 - 04:55 PM
Sorry but I thought this may be ambiguous. In case anyone wonders, we mean our own file sharing, which supports file upload.... the file sharing ...
Posted 15 December 2012 - 05:00 PM
Its tab is on the top.
Oh, thanks, i meant to give a link but forgot
Posted 15 December 2012 - 05:55 PM
First things first, I need to get it off my calculator and onto my computer... Then I guess I'll just upload it to a website I maintainWell, I think you would have to do it through the file sharing since attachments are disabled.
Posted 15 December 2012 - 06:16 PM
Posted 16 December 2012 - 10:06 AM
Posted 16 December 2012 - 04:47 PM
Posted 18 December 2012 - 10:16 PM
It's a problem with linux and the calculator. It exists with xfer9860 too (have to try twice for it to work). I'm not sure if it's because casio didn't implement the USB protocol properly or because the kernel doesn't cooperate with the calc for another reason, but it should be either one of those.
Also tagged with one or more of these keywords: basic
Programming →
Casio Basic →
ASCII conversion table on fx G seriesStarted by Just_A_Noob_Here , 20 Jul 2024 |
General →
Your Projects →
Casio BASIC editorStarted by Tritonio , 11 Sep 2022 |
Calculators →
Casio CFX/AFX/FX/Prizm →
CG50 possible to use program inline?Started by TO-220 , 02 Nov 2019 |
"String Output" Syntax ERRORStarted by hoobigii , 09 Aug 2017 |
Programming →
Casio Basic →
Woodward 2301 Diagnostic Governor ProgramStarted by marcobiaggini , 09 Dec 2015 |
