[Project Idea] Fastbasic
Basic Project Team fx9860
27 replies to this topic
#1 Casimo
Casimo
  • 641 posts
  • Gender:Not Telling
Posted 06 January 2013 - 04:34 PM
I'm planning to make a faster basic-interpreter for the fx-series in c.
The idea: The interpreter uses the same code like the Casiobasic-interpreter. But instead of slow, useless functions I want to use fast ones, for example from Monochromelib or Revolutionfx. I also want to interpret the Send/Receive commands, so they would work.
That means we would play the same basic games like before - but faster and with better quality and new functions.
I already have some good ideas.
But I do not want to program this alone: I want it to be a team project.
So, who wants to join the project?
Edited by Casimo, 06 January 2013 - 05:28 PM.
  • MicroPro and naib864 like this
#2 Forty-Two
Forty-Two
  • Deputy
  • 528 posts
    Casio fx-CG10 Prizm
    Casio fx-9860GII
    TI-84+ SE
Posted 06 January 2013 - 04:50 PM
I suggest that you produce some actual code before asking others to join on the project. This shows that you can actually produce code, and that they won't be doing all the work
On the idea: I really don't see much use for trying to make a faster interpreter. The casio people already have it at a high speed, and they have all the technical documentation (which you have none of). I don't think you will get very far with this.
#3 Casimo
Casimo
  • 641 posts
Posted 06 January 2013 - 04:55 PM
I already started.
code :
#include "stdio.h"
#include "fxlib.h"
typedef unsigned char uchar;
typedef unsigned short ushort;
typedef unsigned int uint;
int LongToAscHex(int value, uchar *dest, int digits);
struct TDirectoryItem{uchar name[8];int offset;int length;char flags[4];};
int App_PRGM(void);
int SearchDirectoryItem( uchar*dir, uchar*item, char*flags_0, struct TDirectoryItem*item_ptr, int*data_ptr, int*data_length );
int InputString( uchar*buffer, uchar *heading, int maxlen );
#define TRUE 1
#define FALSE 0
int data_ptr, data_lenght, pos = 0;
#define CHAR 1
#define CMD 2
#define LOOP 3
#define ASC_A 65
#define ASC_Z 90
#define ASC_COMMA 0x2C
#define OC_QT 0x0022
#define OC_CLRTXT 0x18
#define OC_CLRGRPH 0x19
uchar cursorx = 1, cursory = 1;
void printstr()
uchar str1 = *(uchar*)(data_ptr + (--pos << 1) + 1);
uchar str2;
locate(cursorx, cursory);
cursorx++;
if(cursorx >= 21)
cursorx = 1;
cursory++;
if(cursory >= 9)
cursory = 8;
PrintC(&str1);
while(1)
pos++;
str1 = *(uchar*)(data_ptr + (pos << 1) + 1);
str2 = *(uchar*)(data_ptr + (pos << 1));
if(str2 == OC_QT)
pos++;
Bdisp_PutDisp_DD();
return;
else
PrintC(&str2);
PrintC(&str1);
cursorx += 2;
if(cursorx >= 21)
cursorx = 1;
cursory++;
if(cursory >= 9)
cursory = 8;
char nextoc()
uchar curoc = *(uchar*)(data_ptr + (pos << 1) + 1);
uchar octype = *(uchar*)(data_ptr + (pos << 1) );
pos++;
if(pos > data_lenght)
return 0;
if(octype < 0xF7)
if(octype == OC_QT)
printstr();
switch(curoc)
case OC_CLRTXT:
case OC_CLRGRPH:
Bdisp_AllClr_VRAM();
break;
return 1;
char loadfile()
char program_name[9] = {0};
struct TDirectoryItem item_ptr;
InputString(&program_name, "Open Program : ", 8);
if(SearchDirectoryItem("system", &program_name, &item_ptr.flags[0], &item_ptr, &data_ptr, &data_lenght) != 0)
return -1;
return 1;
int AddIn_main(int isAppli, ushort OptionNum)
char x = 1, txt[5];
if(loadfile() >= 0)
Bdisp_AllClr_DDVRAM();
while(x != 0)
x = nextoc();
GetKey(&x);
App_PRGM();
return 0;
#pragma section _BR_Size
unsigned long BR_Size;
#pragma section
#pragma section _TOP
int InitializeSystem(int isAppli, ushort OptionNum)
{return INIT_ADDIN_APPLICATION(isAppli, OptionNum);}
#pragma section
1. You can open a program.
2. Actually, you can display text and clear the screen.
Edited by Casimo, 08 January 2013 - 03:11 PM.
#4 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 06 January 2013 - 10:39 PM
maybe making something like PRGM2 would be better? But i do think the idea is good.
#5 MicroPro
MicroPro
  • Deputy
  • 640 posts
    Casio ClassPad 300
Posted 07 January 2013 - 11:52 AM
... The casio people already have it at a high speed ...
Nah, they don't. ;) At least on the ClassPad they didn't.
I actually tried to do this for ClassPad two years ago: Look here and here. I called it CP QBasic. Because the code grew long and longer and turned out that I had a bad design, and I kinda lost motivation I stopped; but it wasn't impossible. I could actually get a lot of better speed by just rewriting a parser.
This idea is good. From the opinions people gave me, in case you're going to implement this, try to support some advanced features such as subroutines, etc too.
What is PRGM2?
Edited by MicroPro, 07 January 2013 - 11:56 AM.
#6 Casimo
Casimo
  • 641 posts
Posted 07 January 2013 - 01:40 PM
PRGM2 is a basic extension. It interprets the variables. It looks like this: 1->A
While A=1
WhileEnd
This draws, for example, a box in the middle of the screen.
#7 naib864
naib864
    Casio Technician
  • 316 posts
  • Interests:Programming, Minecraft
    fx-9860GII
Posted 07 January 2013 - 07:33 PM
The Idea of an own basicprogram is great, because casio basic is a bit slow.
Example: The pxl/plot-commands. If you try to create a picture, the program is working a long time.
(I'm new here and I hope my english is okay, because I'm from Germany.)
#8 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 07 January 2013 - 08:19 PM
Your English is great :)
Hello naib864 and welcome to UCF! You should introduce yourself.
#9 naib864
naib864
    Casio Technician
  • 316 posts
    fx-9860GII
Posted 07 January 2013 - 09:34 PM
Thank's! Introduction is online.
#10 MicroPro
MicroPro
  • Deputy
  • 640 posts
    Casio ClassPad 300
Posted 08 January 2013 - 10:41 AM
Yes Casio's implementation refreshes the screen after each drawing operation. But if you refresh the screen "smartly", e.g only in specified intervals and before input commands then you could drastically improve the performance.
#11 louloux
louloux
  • 32 posts
    Graph 85 SD
    Graph 35+
    fx-92
Posted 09 January 2013 - 08:27 PM
Do you know there's a project in the french website, to make a new basic interpreter ? => http://www.planet-ca...asic-Casio.html
  • MicroPro likes this
#12 naib864
naib864
    Casio Technician
  • 316 posts
    fx-9860GII
Posted 09 January 2013 - 08:30 PM
Thanks. I've got Frensh as second language in school, so I try to read this :)
#13 Casimo
Casimo
  • 641 posts
Posted 10 January 2013 - 02:58 PM
I don't understand this project. Is it the same like this? It is coded in c++, but I thought that there is no cout in the sdk...
#14 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 10 January 2013 - 03:02 PM
The sdk can handle c and c++ ;)
#15 Casimo
Casimo
  • 641 posts
Posted 10 January 2013 - 03:04 PM
I know, but I don't know if the SDK has a "<<" ">>" or cout-function
Edited by Casimo, 10 January 2013 - 03:05 PM.
#16 louloux
louloux
  • 32 posts
    Graph 85 SD
    Graph 35+
    fx-92
Posted 10 January 2013 - 08:13 PM
This is actually just a parser.
It will become :
-an emulator on computer
-a new oncalc Basic interpreter
Other questions about the project ? Translation ?
#17 Casimo
Casimo
  • 641 posts
Posted 11 January 2013 - 02:53 PM
Ok, now I understand. So the oncalc project hasn't been started yet.
#18 naib864
naib864
    Casio Technician
  • 316 posts
    fx-9860GII
Posted 12 January 2013 - 08:35 AM
But the first question was who is going to work with Casimo.
And I say yes.;)
#19 Casimo
Casimo
  • 641 posts
Posted 12 January 2013 - 09:21 AM
Ok, you want to work with me? That's great!
I continued programming:
#include "stdio.h"
#include "stdarg.h"
#include "fxlib.h"
int App_PRGM(void);
#define TRUE 1
#define FALSE 0
#define CHAR 1
#define CMD 2
#define LOOP 3
#define ASC_A 65
#define ASC_Z 90
#define OC_QT 0x22
#define OC_NL 0x0D
#define OC_LCTE 0x10
#define OC_PXLON 0xAB
#define asctonum(x) (x - 48)
#define INVALID_CHAR -2
#define INVALID_VAL -3
#define SUCCESS 1
void throwerr(char errcode)
uint key;
PopUpWin(2);
locate(3,3);
Print("Error!");
locate(3,4);
switch(errcode)
  case INVALID_CHAR:
   Print("Invalid character");
   break;
  case INVALID_VAL:
   Print("Invalid parameter");
   break;
GetKey(&key);
void addtostr(char **ptr, uchar lenght, char c)
char *temp = (char*)malloc(lenght + 2);
memcpy(temp, *ptr, lenght);
*(temp + lenght) = c;
*(temp + lenght + 1) = 0;
free(*ptr);
*ptr = temp;
char arg(uchar count,  ...)//This should become a function that reads the arguments of a command. This isn't ready yet!
uchar num;
uchar i;
uchar space, *pval;
va_list vl;
va_start(vl, count);
for (i = 0; i<count; i += 2)
  pval = va_arg(vl, uchar*);
  space = va_arg(vl,uchar);
  num = asctonum(*(uchar*)(data_ptr + pos++));
  if(num <= 9 && num >= 0)
   *pval += num;
  else
   va_end(vl);
   return INVALID_CHAR;
   *pval += num * 10;
  else
   if(*(uchar*)(data_ptr + pos - 1) != space)
    va_end(vl);
va_end(vl);
return SUCCESS;
char getarg(uchar* val1, uchar space1, uchar* val2, uchar space2)//The actual function. It supports 2 Digits, the interface is like this: CommandParam1char1Param2char2
//for example: Locate 10,2,
uchar num = asctonum(*(uchar*)(data_ptr + pos++));
*val1 = 0;
*val2 = 0;
  *val1 += num;
else
  *val1 += num * 10;
else
  if(*(uchar*)(data_ptr + pos - 1) != space1)
  *val2 += num;
else
  *val2 += num * 10;
else
  if(*(uchar*)(data_ptr + pos - 1) != space2)
return SUCCESS;
void printstr()
uchar str = *(uchar*)(data_ptr + pos++);
cursorx++;
if(cursorx >= 21)
  cursorx = 1;
  cursory++;
  if(cursory >= 9)
   cursory = 8;
PrintC(&str);
while(1)
  if(str == OC_QT)
   Bdisp_PutDisp_DD();
   return;
  else
   PrintC(&str);
   cursorx ++;
   if(cursorx >= 21)
    cursorx = 1;
    cursory++;
    if(cursory >= 9)
    cursory = 8;
void basiclocate()
char err = getarg(&cursorx, ',', &cursory, ',');
if(err < 0)
  throwerr(err);
void basicpxl()
uchar x, y;
char err = getarg(&x, ',', &y, OC_NL);
if(x > 127 || y > 63)err = INVALID_VAL;
if(err < 0)
  throwerr(err);
  return;
Bdisp_SetPoint_VRAM(x, y, 1);
Bdisp_PutDisp_DD();
char nextoc()
uchar opcode = *(uchar*)(data_ptr + pos++);
return 0;
if(opcode < 0xF7)//if the opcode is a character
  switch(opcode)
   case OC_NL:
    return 1;
   case OC_QT:
    printstr();
    return 1;
switch(opcode)//if the opcode is a function with the prefix 0xF7
  case OC_CLRTXT:
  case OC_CLRGRPH:
   break;
  case OC_LCTE:
   basiclocate();
   break;
  case OC_PXLON:
   basicpxl();
   break;
return 1;
char loadfile()
return -1;
return 1;
char x = 1, txt[5];
if(loadfile() >= 0)//load the file
  while(x != 0)
   x = nextoc();//loop through data
  GetKey(&x);//wait
App_PRGM();//call PRGM-App
return 0;
I send you more infos soon.
#20 MicroPro
MicroPro
  • Deputy
  • 640 posts
    Casio ClassPad 300
Posted 13 January 2013 - 12:18 PM
This Pylaterreur guy seems very knowledgeable... Doesn't he visit English forums?
I think his code was also very well-structured, although being object-oriented can slow it down a few milliseconds or so...
I wonder if you guys want to cooperate with him (or him cooperate with you) for making your alternate Basic interpreter? Already having a parser will save you a lot of trouble.
#21 Casimo
Casimo
  • 641 posts
Posted 13 January 2013 - 01:43 PM
Sorry, I simply don't understand what a parser does / why this parser helpful is xD
Could someone explain it?
#22 louloux
louloux
  • 32 posts
    Graph 85 SD
    Graph 35+
    fx-92
Posted 18 January 2013 - 06:42 PM
A parser is a program which reads a Basic code. It's as the main motor.
If you add all functions it becomes an interpreter ;)
Both english community and french community play their part. We're an active community and we don't really know yours...
#23 Casimo
Casimo
  • 641 posts
Posted 18 January 2013 - 08:12 PM
Ah, now I know. Thank you for your explaination.
#24 Cartix
Cartix
  • 18 posts
    Classpad
Posted 21 January 2013 - 04:25 PM
Is it possible to get the source of this add-in ?
Edited by Cartix, 21 January 2013 - 04:25 PM.
#25 MicroPro
MicroPro
  • Deputy
  • 640 posts
    Casio ClassPad 300
Posted 25 January 2013 - 05:37 PM
More specifically, it provides functions that replace your nextoc, getarg and other functions that need to parse the file.
Of course you are. Many French programmers visit here. But I always thought programs written by the English community had more audience.
Of course. I will post it in its own topic (the second one) when I get some time.
#26 louloux
louloux
  • 32 posts
    Graph 85 SD
    Graph 35+
    fx-92
Posted 26 January 2013 - 09:16 PM
More audience ? I have 8063 downloads :P
#27 naib864
naib864
    Casio Technician
  • 316 posts
    fx-9860GII
Posted 26 January 2013 - 09:27 PM
Yes, but this site is no site for downloading games, programs,…, it's a forum.
Edited by naib864, 26 January 2013 - 09:28 PM.
#28 Forty-Two
Forty-Two
  • Deputy
  • 528 posts
    Casio fx-CG10 Prizm
    Casio fx-9860GII
    TI-84+ SE
Posted 28 January 2013 - 03:12 PM
Actually, it is, but the dl section has not been updated since the site was first founded.
Also tagged with one or more of these keywords: Basic, Project, Team, fx9860
