the issue I came across recently is when downloading RECKON addon which is designed for fx 9860g slim , where as mine is fx 9860gii, it is running fine but the function oft the buttons is totally different ,for example trying to press F2 gives me X, even trying to know each button does not help becuase buttons like exe AND AC will work with respect to the real calculator no matter what ever is it
problems with casio fx 9860 g ii add on
casio does minecraft
, Jan 18 2017 05:23 PM
code fx-9860gii add-ons
Posted 18 January 2017 - 05:23 PM
Posted 24 January 2017 - 02:11 PM
I do not have fx-9860G SLIM, but have fx-9860GII. I'm afraid those two calcs may have different keycode assignment.
To get rid of this possibility, I think you should check with instruction manuals of those which you can get from internet.
Please check.
Also tagged with one or more of these keywords: code, fx-9860gii, add-ons
Calculators →
Casio CFX/AFX/FX/Prizm →
CAS From Classpad 330 to fx-9860giiStarted by RAMBOFAKER , 15 Jan 2024 |
General →
Your Projects →
Need help with KEY_CTRL_UP/DOWN/RIGHT/LEFTStarted by mogus69 , 13 Jul 2022 |
General →
Your Projects →
Essential FPS game scriptsStarted by FrankJ , 19 Jan 2021 |
Calculators →
Can programs be run directly from an SD card on the FX-9860GII SD? IfStarted by childishbeat , 19 Nov 2019 |
Calculators →
Is there a battery add-in for the fx-9860GII ver. 2.04?Started by Gabriel Miceli , 31 Aug 2018 |
