Problem of building an Add-in
fx-9860G
#1 diaowinner
diaowinner
  • 8 posts
    CASIO fx-991CN X
Posted 08 March 2020 - 02:32 PM
I have a problem for build an Add-in using fx-9860G's SDK, when I click Project menu → Build, I saw this...
Executing Hitachi SH C/C++ Compiler/Assembler phase
set SHC_INC=F:\fx9860g_sdk_100\software\OS\SH\include
set PATH=F:\fx9860g_sdk_100\software\OS\SH\bin
set SHC_LIB=F:\fx9860g_sdk_100\software\OS\SH\bin
set SHC_TMP=G:\aaaaaaaaa\a\Debug
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 92
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 109
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 126
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 143
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 160
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 177
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 194
	WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 211
Executing Hitachi OptLinker04 phase
"F:\fx9860g_sdk_100\software\OS\SH\bin\Optlnk.exe" -subcommand=C:\Users\ADMINI~1\AppData\Local\Temp\hmkFC50.tmp
** L2300 (E) Duplicate symbol "_AddIn_main" in "G:\aaaaaaaaa\a\Debug\Revolill.obj"
Optimizing Linkage Editor Abort
HMAKE MAKE UTILITY Ver. 1.1
Copyright (C) Hitachi Micro Systems Europe Ltd. 1998
Copyright (C) Hitachi Ltd. 1998
	ERROR: Process failed with return code: 1
Build was not successful.
Then nothing happened! Can someone help me? :iwstupidl:
#2 TBit
TBit
  • 26 posts
  • Interests:C/C++, Assembly, Demoscene
    FX-9860 GII
    FX-9750 GII
    ClassPad 330 PLUS
Posted 08 March 2020 - 04:36 PM
Where is your function definition of AddIn_main? Is it in a single source file or a header? You have to make sure the symbol
is only exported from one object file.
I think it would help if you posted the contents of your Debug/*something*.map file, too.
Edited by TBit, 08 March 2020 - 04:42 PM.
Also tagged with one or more of these keywords: fx-9860G
