Hello,
I am trying to connect my calculator to my computer so that I can download the programs that I've written on my calculator onto my computer. I downloaded the FA-124 program and installed the drivers. When I plug the calculator into the computer, I get a message on my screen that says "Select Connection Mode". I press for DataTrans, and then my calclulator shows a message that says "Receiving..." Then, when I click the "Connect" button on the FA-124 program, it displays a message saying:
"A connection could not be established.
Either the calculator is not connected or the connected calculator is not in the data recieve standby mode."
I don't know if this info is needed, but the Casio program is FA-124 Ver.2.04 for Windows. I use Windows 10. The communication settings on the calculator are:
Cable Type: USB
Wakeup: On
Capture: Memory
Can anyone tell me how to fix this problem or what I should do differently to connect my computer to the calculator?
Thanks
