Cahute is a library and set of command-line utilities to manage protocols and file formats used with CASIO calculators from the early 1990s to today. It is compatible with both Linux and macOS / OS X, and Windows support is on the way.
With release 0.2, published on 2024-03-24, the features are the following:
- File transfer in both directions for fx-9860G, on USB and serial modems.
- Screenstreaming from both fx-9860G and fx-CG, on USB only.
- fx-9860G flashing support, using fxRemote method (until we have better native support available).
Links for the project are the following:
I take all feedback ![]()
