Hi, I got the FA-123/124 SB-88 cable, but where can i get driver for this cable, I know that there is a cd that includes driver (Casio usb to rs232 //usb2kpx) and software for this cable, I didn’t receive any CD. Help is really appreciated!![]()
Need help with Casio SB-88 Cable.
Posted 15 May 2024 - 02:28 PM
- fx-9750GA+ and NIPro like this
Posted 05 September 2024 - 03:43 PM
NIPro, according to a website, if you are using window 10 and later, you can use device manager to load the proper driver. Could you please tell me how you were able to order the SB-88 cable? The Asian Gentlemen's website no longer is working. Also, the FA-123/124 program interface download, also is not working. I would appreciate if you could send me the info. Thanks, in advance!
Posted 07 September 2024 - 05:28 PM
Hi NIPro,
do You mean this? Since it was the only thing I found:
https://mega.nz/file...N_lL6quXYBRMSG0
I found it from my folders, and decided to upload.
I think it's the one, since it starts with the same number that you mentioned.
Also this is the 32-bit version - (but I am not quite sure if it had 64 bit...)
Tbh I forgot how do you set it up.
But I do remember one thing, in my personal experience, it worked perfectly on old 32bit windows xp pc, not on windows 10.
(maybe I set the whole thing wrong...)
On new system it freezes, also the contents, which are transfered are not properly transfered its like I have a program:
"hi what do you want to input?" ? -> X
and when I transfer to my calculator, there are little incorrect spots it would look like roughly:
"éh wh^t do you €ant to input?" ? -> X
so after transfer I have to check and manually edit the spots...
I can look up the cd where the unofficial manual is included.
Have a nice day,
- Nooblette
Also tagged with one or more of these keywords: Cable, Casio CFX, CFX9850GBPLUS, Driver, Software, SB-88, FA-123, FA-124
General →
Your Projects →
Cahute, a toolset for protocols and file formatsStarted by Cakeisalie5 , 29 Mar 2024 |
Where i can buy FA-123 cable for cheap?Started by NIPro , 23 Mar 2024 |
General →
General Discussion →
FA-124 how to import '.g1a'?Started by yongd , 29 Oct 2022 |
General →
Technology and Hardware →
USB port issuesStarted by FrankJ , 16 Jan 2021 |
Calculators →
Casio CFX/AFX/FX/Prizm →
Computer is not detecting my Casio fx-9750GII when I try to connect usStarted by theEskimo , 03 Jan 2020 |
