Well, I have heard of some weird problems before, but this one takes the cake.
I was using my calculator and I heard and felt a "pop". The calculator still works fine though... I even tried overclocking it.
That was yesturday. Three times so far since then, my calc has been making these little sizzling noises. I am not sure how to explain it... they sound kind of like a "shhshh" sound and only last about a second. However, my calc seems to be working perfectly.
So I want to know what reasons for this the rest of you can come up with, since I am pretty puzzled by the whole thing.
So far, the only explanations I can come up with are:
1. The "pop" was a capacitor exploding. But that doesn't make sense because the calc still works.
2. Maybe water got under one of the keys (I can see some water between and under the lower row of keys, I am going to see if I can get it to dry up) and the "pop" was because one of the keys was being held down by the suction and finally popped up.
I don't know how to explain the sizzle though.
6 replies to this topic
Posted 20 August 2012 - 02:03 PM
Posted 20 August 2012 - 04:47 PM
maybe the dielectric of that key became soaked and when you press it the water get electrolysed and some oxygen and hydrogen are escaping. just a wild guess
Posted 20 August 2012 - 05:35 PM
Yeah, its totally weird. Especially since the calc works perfectly fine...
Posted 20 August 2012 - 09:12 PM
maybe a battery issue, was there any strange smell?
Posted 20 August 2012 - 10:09 PM
No strange smell, but my batteries were low (they ran out all the way about an hour ago.) However, I have no new batteries so I can not verify that that was the issue yet.
Posted 22 August 2012 - 09:47 AM
My phone's camera shutter sizzles when I connect/disconnect the charger, but how can a "rock-solid" device as a calc make such sound?
But if anything has exploded or is leaking you should feel some horrible smell at least.
If you dare, open the calc and verify the physical look of the parts. (Make sure you don't break warranty seals; if you found any, don't open it)
Posted 22 August 2012 - 03:28 PM
Nah, I don't think I'll open it. It seems to be working fine, so I won't bother. But this is a sort of weird problem.
Also tagged with one or more of these keywords: prizm, click, pop, sizzle
Calculators →
Casio CFX/AFX/FX/Prizm →
fx-CG50 USB connection to Android tabletStarted by Sal , 12 Jan 2020 |
Programming →
General Help →
Help with casio fx-CG50Started by RASM9805 , 13 Jul 2019 |
Calculators →
Function For Distance Between 2 Parametric EquationsStarted by Sumaxi , 13 Apr 2015 |
Calculators →
Domain And Range On Prizm Calculator.Started by matutemats , 29 Mar 2013 |
prizm
Calculators →
Built-In Syntax Help?Started by flyingfisch , 03 Dec 2012 |
