I was fooling around with test mode on the prizm, and got to the setup menu, with no options left out. In this menu, at the very bottom is an entry called "Syntax Help". It is unchangeably set to "off".
What would syntax help do? Is it included in any other casio calculator setup menus? Was it already available at one time and they decided to remove it, or is it going to be available sometime in the future?
No replies to this topic
Also tagged with one or more of these keywords: prizm
Calculators →
Casio CFX/AFX/FX/Prizm →
fx-CG50 USB connection to Android tabletStarted by Sal , 12 Jan 2020 |
Programming →
General Help →
Help with casio fx-CG50Started by RASM9805 , 13 Jul 2019 |
Calculators →
Function For Distance Between 2 Parametric EquationsStarted by Sumaxi , 13 Apr 2015 |
Calculators →
Domain And Range On Prizm Calculator.Started by matutemats , 29 Mar 2013 |
Programming →
General Help →
Insight For PrizmStarted by flyingfisch , 28 Nov 2012 |
