Error Using Fxremote To Backup Fx-9750Gii Before Flash To Fx-9860
FX-9750GII fxRemote backup flash FX-9860 error
#1 PhyscoKillerMonkey
PhyscoKillerMonkey
    Casio fx-9750GII
Posted 04 March 2015 - 11:24 PM
I have just got a Casio FX-9750GII and was disappointed (like many) to find that there is no natural display option so wanted to flash a FX-9860 image.
Firstly am I correct in believing that an OS Version 02.04.0701 means I have the GII-2 model and should be flashing the SH4 image.
Secondly I tried to "Backup flash" in fxRemote 2.0.21 and get "Error 04: Overwrite impossible/requested file does not exist. Backup is supported by Link/receive-mode only!" I am pretty sure that my drivers are working as I can copy programs to the calculator so does anybody have any idea what I could do to remedy this? (I could just flash the new image but I would like to make a backup before hand)
Here is the output from fxRemote:
00:00:00.002:FStart in
00:00:00.103:start...
00:00:00.103:...waiting for answer!
00:00:00.105:...waiting for answer!
00:00:00.105:...successful!
00:00:00.106:FStart out
00:00:00.106:...waiting for answer!
00:00:00.133:...waiting for answer!
00:00:00.133:...successful!
00:00:00.134:File opened: D:\User Files\Downloads\Calculator Stuff\fx-9750GII_tools_distro\fxRemote\cxz-fxRemote.fls.RAM
00:00:00.135:Flash transfer request...
00:00:00.135:...waiting for answer!
00:00:00.159:...waiting for answer!
00:00:00.160:...failed!
(Also I am completely new to the world of graphing calculators so please explain the specifics of things if possible, thanks (: )
Edited by PhyscoKillerMonkey, 04 March 2015 - 11:27 PM.
#2 Viliami
Viliami
  • Moderator
  • 99 posts
  • Interests:C++ - OpenGL,SDL
    Python - Pygame
    Java - SFML
    C - Casio SDK
    FX-9750 GII upgraded to FX-9860 GII
Posted 30 November 2015 - 01:21 AM
Download the fls file from here:
[link removed]
It's not working because you're using OS 2.04 and you're probably trying to update using the OS 2.02/2.01 files.
"Backup is supported by Link/receive-mode only!"
I think this is because you are just connecting the USB to your computer without putting it into the bootcode screen.
This is how to get it into the bootcode screen btw:
(**) Start bootcode OS updater: (GII models only)
- Press F2+4+[AC/on]+RESTART at the same time
- Release the RESTART button
- Release F2+4+[AC/on]
  * The display will be blank
  * for about five seconds and
  * then the OS should boot.
  * During this period:
- Press 9 and release it
- Press × and release it
Just use the files above with fxremote and put the calculator into the bootcode mode and then it should upgrade properly.
Edited by 2072, 30 November 2015 - 07:06 PM.
removed link to copyrighted material
Also tagged with one or more of these keywords: FX-9750GII, fxRemote, backup, flash, FX-9860, error
