I wanted to find out if I could use a USB To Go adapter with my Android tablet, to load files onto my fx-CG50. It worked!
My tablet is a Samsung Galaxy View 18.4 running Android 5.1.1. The fx-CG50 mounted as "USB Drive A" on the tablet. I transferred a couple .g3m files that I got from charliewilson.com from the tablet to the fx-CG50. Then I used the Android pull-down menu to select the option to dismount the USB device. The fx-CG50 popped up a screen (I forget the exact wording) about the fx-CG50 updating files. Then I disconnected the USB cable and was able to select and run the new files, just as if copied from a regular PC.
The only slightly unusual thing is that the OS on my tablet also created two directories on the fx-CG50 just like it would on a USB "Thumb" drive:
Android
LOST.DIR
(The LOST.DIR) is also from memory, but I've seen it enough to be pretty sure I got the name right.
Anyway, I am happy that I can copy files using Android. These days I hardly use anything else
fx-CG50 USB connection to Android tablet
Sal
, Jan 12 2020 03:28 AM
fx-CG50 CG50 Prizm Android
Also tagged with one or more of these keywords: fx-CG50 CG50, Prizm, Android
Programming →
General Help →
Help with casio fx-CG50Started by RASM9805 , 13 Jul 2019 |
Calculators →
Casio CFX/AFX/FX/Prizm →
Function For Distance Between 2 Parametric EquationsStarted by Sumaxi , 13 Apr 2015 |
Calculators →
Domain And Range On Prizm Calculator.Started by matutemats , 29 Mar 2013 |
prizm
Calculators →
Built-In Syntax Help?Started by flyingfisch , 03 Dec 2012 |
Programming →
General Help →
Insight For PrizmStarted by flyingfisch , 28 Nov 2012 |
